Nautilus quick connect issue
The spring loaded quick connect on our tab 400 shower hose fell apart. I was unable to locate the small internal retaining pins so I cannot reassemble. I think the outer plastic sleeve is pretty flimsy which can allow this connection to fall apart if stressed a little too much. Anybody out there replaced this with something more substantial?  The connector screws off the nautilus easily but the threads are going to require some adapters in order to use more common fittings. Thought I would check alternatives before locating the OEM part. Regards.
