Noticed the red lamp on my interior lights it reads doesn’t turn off. At first I thought it was a bad fuse, swapped fuses and still lit up. Interesting is, when I remove the fuse it lights brighter than it is. And returning the fuse it dims. Other fuses when removed light up bright and turn off when returned. Anyone have insight on this?
'Fuse Keeps Burning Out' https://tab-rv.vanillacommunity.com/discussion/13210/fuse-keeps-burning-out
The better solution, of course, would be for manufacturers to stop using this cheap and dirty indicator method. An inexpensive logic circuit embedded in the fuse block would provide the desired indicator function without providing the sneak current path provided by the inline indicators now being used.
Just sayin'
As for the OP, normally the resistance across the fuse is much lower than across the resistors and LED. So either there is a bad solder joint at the fuse holder, or one of the resistors is wrong (total across all three measured 2k) and makes the LED glow a bit.
Historically these false fuse failure LED situations are caused by the USB Ports. The USB Ports are (also) made cheap and frequently outright fail or leak current when not-in-use enough to light the LED.
