No, but it seems like a good idea because it would be easier to change the tire in the event of a flat. I plan on abandoning my knobby 235’s as soon as they are anywhere near wearing out.
ST tires have a history of blowouts. We replaced four Good Year Marathons on our Airstream after many many reports of sudden blowouts and instant trailer damage, just as a safety measure. So many complaints Airstream finally made Michelin LTX tires standard equipment.
Doug K
Douglas and Cheryl both Navy Retired 2022 Tab 320s Boondock/2021 Honda Ridgeline BE Minnesota and Arizona
-+- Tire has 100% same load/speed rating as the OEM on my trailer. -+- Tire is also 'XL' construction like the OEM.
'XL' contruction does have additional
material added to the shoulder of the tire for extra strength . . . Tires
that are engineered with reinforced sidewalls are considered to be XL
or RF tires (with RF tires having even more reinforcements than XL
tires.)
WAG would say 'ST' are nearer the 'RF' end of the range. 'ST' also have less rolling resistance compared to traction [XL] tires. I can see how shifting to the road tread instead of the OEM mud/snow tread might help a bit on towing MPG.
Thanks for the lead . . .these are on my to be considered list.
'18 320 S, pitched axle, 3020HE; PNW based TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller Adventures: 51Nights: 322 Towing Miles 41,200+
I owned a 320, changed to Goodyear, upgraded to a 400, went to Goodyear immediately, better tire, smoother rolling for better gas mileage performance and peace of mind
Don't Forget all most " ST " construction tires are speed rated at 65 MPH
So when driving in states like Wyoming with 80-MPH speed limits {and no clear trailer/truck speed limit} and if you are a Peddle-to-the-Metal driver Be Careful.
Generally I tow in the 60-65 MPH range even on 80 MPH interstates but have been known to hit 80+ when passing or due to other traffic events (TaB has always 'tracked' 100% okay). My OEM tires have a 100+MPH rating.
Just my view. I paid extra to get the BD package. Mostly for the extra ground clearance. This comes from the “pitched” axle and the larger tires. I would not go smaller on tires unless there was no option.
2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4 2018 TAB 320 Boondock (previous) Odessa, Fl.
I agree and won't put a smaller tire on my 400 BD. I have many miles left on my original tires but when they need replacing I'll either replace with the original ones or put a good E rated LT tire on the trailer.
Just a comment on the Goodyear Endurance tires on a T@B 400. Last summer a local 400 (2018 not a Boondock model) went all the way from Vancouver Island up the interior of B.C. to Dawson City and then the gravel up the Dempster Highway to cross the Arctic Circle. And repeat south to home again; all without a single blowout or hiccup. While the tires were fine and still looked like new, the frame needed some paint touch-ups! Definitely the tire I'm changing too before our next long trip.
Hans Peter, Nanaimo, Vancouver Island 2019 T@B400 Rogue 2012 VW Touareg 3.0 TDI
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Doug K
Adventures: 51 Nights: 322 Towing Miles 41,200+
2019 T@B 400 BL
2019 Ford F-150 3.5L Ecoboost with Long Bed
N (87 mph)
Load Index
105 (2039 lbs)
Load Range: D
Odessa, Fl.
Odessa, Fl.
by nearly 1-inch compared a '235'.
Several web-resources are available to review; for example:
2019 T@B400 Rogue
