Isabella Sun Canopy Set up
NoVaGuy
Member Posts: 95
I have the isabella sun canopy for my Tab 400. I have now had it set up several times and it never seems quite right. The forward flaps do not reach the ground. Also, the two side poles do not seem to connect to the arch properly. The ends are at an angle. I must be doing something wrong.
Does anyone have any tips or suggestions for getting this set up properly?
2020 T@B 400 BD Lite
Is there a regular vs Boondock Isabella model?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
It was supposed to be for both the standard and Boondock model of the Tab 400
2020 T@B 400 BD Lite -
This is Mandy Lea's 400. The front fabric doesn't touch the ground either. Not sure about the poles. Maybe post a photo. There are some install videos for the 320 but haven't seen one for the 400.
I have the Isabella on our Boondock, and the “flaps” do not reach the ground on mine either, especially when I have the adjustable feet extended. And I agree the poles on each end do not hit and connect to the frame squarely, but seem to hold just fine.
Thank you for the sanity check TNOutback. The side poles hold fine, it just seems like for the price they charge, the design could be more refined such that the side flaps and the side poles actually do what is expected.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
