How to Drain the line from water tank to water pump
RollinWithShirley
Member Posts: 40
I blew out my water lines for winter via the city water connection. I don't think that pushed the water out in the line between my water tank and the pump and I sprang leaks there. Does some one have a complete protocal for draining with air compressor for T@B 320 Outback?
(Oops see comment below for pre-2021 model.)See 104 here (Winterizing with Nautilus):
https://tab-rv.vanillacommunity.com/discussion/6372/winterizing-manuals#latest
@Sharon_is_SAM, @RollinWithShirley has a 2015 320. I found that info on another thread.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
dragonsdofly......i am not sure how to access that thread.
@RollinWith Shirley, you posted the year and model of your t@b under "Norcold not cooling" by Tabaz.
P.S. to adress or direct a comment to a forum member so they receive a notification that you have adressed them (question, mention, etc) use the "@" before their forum name. If you don't, they don't get any notification that you have mentioned them or asked them a question unless they reread that exact thread. Good luck with your fridge problem.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Oops! @RollinWithShirley - for pre-2021 320 models, see Winterizing 102 here: https://tab-rv.vanillacommunity.com/discussion/6372/winterizing-manuals#latestSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
