Our Jensen radio paired with our iPhones just fine for 4 weeks but recently we cannot get a connection. Has anyone else had this problem? My method is to select the Bluetooth mode, then hold enter down for 3 seconds, then Pairing appears on the Jensen screen but no device can connect. I have also tried the Reset on the Menu, tried turning Bluetooth and my phone and the radio off and on again, but my phone does not even see the JWN device anymore.
2018 T@B 400
Sw@llowt@il - 2015 Highlander - Dunedin, Florida
Not all that wander are lost..." J. R. R. Tolkien
0 ·
2019 Ford F-150 3.5L Ecoboost with Long Bed
"Not all that wander are lost..." J. R. R. Tolkien
Good Luck
Wayne
2024 T@g 5-wide Black Canyon
I have to power resetm it (battery disconnect for ten seconds) every time I return to try to buetooth it again. This cannot be right.
I have other bluetiooth devices that remain paired and useable when left alone and I attempt to reuse them. I don't accept that this is the only way to use this radio (Jwmb6a). I realize this as a workaround. Who should we work with to get this fixed?
I find I use my radio and TV unit less and less, but I also want to point out that customer service from ASA electronics for my wonky radio was very helpful. See this thread for details
https://tab-rv.vanillacommunity.com/discussion/9927/2019-jensen-jwm70a-dvd-cd-radio-loading-loading-loading#latest
Bottom line: I do not see this being fixed by either Jensen or any other RV manufacturer. This tech is on the way out. Likely a better use for the space anyway
2025 Ram 1500 “MTFLY”
2025 Tab 360cs (in production) “Honey Pot”
”Honey attracts more flies than vinegar”
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
