Smart shunt install question
homerdhomerd Member Posts: 37
My smart shunt is always showing 100% charge. I have all loads going to the load side of the shunt. This includes one negative from the bus bar ( since the charger/inverter negative goes to it), the SAE plug for external solar panel, and the solar controller. Only one wire going to the batter negative from battery side of the shunt. Any suggestions? This is lithium install inside my tab.
2022 Tab 320S Boodock
2012 Toyota 4Runner SR5
2013 KZ Durango 336RE
2013 Chevrolet 2500HD LTZ Duramax
Akron, Ohio Summer/Fall and out camping
Largo, Florida Winter
    Maybe the solar is keeping up with the loads.  Try applying a large load (inverter) or turn off the solar charger through the app (I believe you can do that).
    Unrelated, are the charger and inverter the same component?  Or is it a charger/converter (AC converts to DC)?
    Rich
    2019 T@b 400
    Bellingham WA
  • elbolilloelbolillo Member Posts: 511
    If you disconnect the power the BMV will start at 100% after reconnecting. You have to make a full charge and the SOC should be correct then.
  • pthomas745pthomas745 Moderator Posts: 4,194
    The Victron App has a "Charger Enabled" switch in the "Battery Sections" menu.
  • homerdhomerd Member Posts: 37
    Thank you, will do
