Tab 320s door locking mechanism issues
CanadianTabber
Member Posts: 148
Hey all,
When I lock the door on my Tab 320s and pull it to check if it locked, it unlatches slightly....its not completely unlocked, and I have to use the key to fully open it, but its not right.
Anyone else experiencing this?
Thanks!
Brent
Thanks!
Brent
Toronto, Canada
Toronto, Canada
It seems mine does that, too. I think what is happening is the latch holds the door a little more snugly than the deadbolt (which is what you are engaging with the key). The door is no less locked in either case.2015 T@B Max S (320)
Thanks Scott!2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada1 -
Hello. I just bought a 2022 320s and had the same issue with the door. I watched this video on YouTube and fixed the issue myself. The 320 was actually easier to fix than the 400 because there was less stuff to remove. I used 2 washers behind each screw. The door is way more secure now.Here is the link to the video.Hope this helps.1
