Tab 320s door locking mechanism issues
Hey all,
When I lock the door on my Tab 320s and pull it to check if it locked, it unlatches slightly....its not completely unlocked, and I have to use the key to fully open it, but its not right.
Anyone else experiencing this?
Thanks!
Brent
2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada
    It seems mine does that, too. I think what is happening is the latch holds the door a little more snugly than the deadbolt (which is what you are engaging with the key). The door is no less locked in either case.
  • CanadianTabber
    CanadianTabber Member Posts: 148
    Thanks Scott!
    Toronto, Canada
  • Darcy
    Darcy Member Posts: 6
    edited September 2022
    Hello. I just bought a 2022 320s and had the same issue with the door.  I watched this video on YouTube and fixed the issue myself.  The 320 was actually easier to fix than the 400 because there was less stuff to remove.   I used 2 washers behind each screw. The door is way more secure now.
    Here is the link to the video.
    Hope this helps.
