You can use the Fantastic fan any time. Depending on the angle of the rain, you may need to keep it mostly closed. It has to be open some of the fan won't come on.
First thing I did was add a vent cover. Can be fully open in the rain with no leaks. You get stuck inside during a long storm and you'll be glad you have one.
2021 T@B 320 S Boondock 2025 KZ Sportsmen 130RD 2025 Ford Ranger The Finger Lakes of New York
@SLJ can you share which cover you added and your experience with installation? I'm considering adding a cover or replacing with the Maxx Air Maxxfan Deluxe 7500k.
I think you were one of the last TaB400s modified by nüCamp, as they no longer offer this option, as the newer TaB 400s have a smaller round exhaust/vent fan in the washroom. Cheers
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
I think you were one of the last TaBs modified by nüCamp, as they no longer offer this option, as the newer TaB’s have a smaller round exhaust/vent fan in the washroom. Cheers
The 320s don't have a bathroom fan. I had to install one in mine.
For another approach, I added a speed control to the original bathroom fan. I prop the bathroom door open and run it on low speed. Water never comes in.
Hikerchick, I can't tell if you have a rain sensor or not. The NuCamp manual for your 400 refers to the bag of owners manuals that came with your trailer rather than explainig what was installed. If you have a rain sensor, there will be a blue sticker that looks like a cartoon rain drop. You will also have a remote for the vent.
@hikerchick - My 2021 400BD had a model 1450 Fantastic Fan which is different from the former model 1250 in that it does not have a rain sensor like the earlier models. It also does not have a kill switch which shuts the fan down when the lid closes. Dometic claims that the 1450 can be operated at full speed with the lid closed while the earlier models (1250) are not designed to do so. Of course that moves air but does not provide any ventilation.
I replaced my Fantastic Fan 1450 with a MaxxFan Deluxe primarily because it can be fully open and operating in the rain (it is also quieter, more energy efficient, and better all around quality). It seems to me that being able to have ventilation in the rain is a very important feature.
You can add an external hood over the Fantastic Fan, which ours has, and you can open to max, and use the fan in the rain, unless it is a driving hurricane force wind doing at you from the rear… :# cheers
It looks like hoods such as the Camco 21015 require drilling through the roof into the cabin interior for its attachment bolts. Is this the case?
The Camco 40421 attaches directly to the side of the existing fan unit - not to the roof. I have a brand new / never installed one in white which I will provide for free - just the cost of shipping. I bought it and then decided to replace my Fantastic Fan with a MaxxAir. The 40421 is 1.25 inches lower than either of the Fantastic Fan or MaxxAir hoods. This model can be opened to provide access to the fan from the roof if ever needed without removing it.
I installed the Camco Aero-flo myself. I didn't have to drill through the roof. You attach brackets to the side of the existing vent and then the cover attaches to the bracket. It's one of the best improvements that I made to my trailer. I also installed the variable speed motor hack described in this thread.
San Francisco Bay Area 2013 CS-S us@gi 2015 Toyota Tacoma PreRunner Double Cab
We generally keep the fan lid open only a bit more than the shut off switch allows the motor to turn ON for cabin venting when cooking or it's very hot and on city power (rare). We've owned the 320 for over 2 years and never had a rain entry problem. Though it's very rare for us to be in a driving rain. Otherwise we get a lot of rain in the Pacific NW. What are the conditions users have found water entry that lowering to this point would not solve? Note we also modified the speed switch with the variable speed mod - THAT was one of the best and easiest changes on the trailer. I'm wondering if those in very hot situations where max airflow is important and dislike moving the cover from full open to minimally open? We've not been there yet.
Snohomish WA, 2015 Diesel Grand Cherokee Sm@ll World: 2021 320S Boondock, 6V Pb-acid Shunt, Roof & Remote solar & 30A DC-DC Chargers managed by VE Smart Network
"Just Enough"
2017 Highlander Limited
2025 Ford Ranger
2022 F-150
Gratitude
"Just Enough"
2025 Ford Ranger
Southern California
Full-timer since 2019
2025 Ford Ranger
Jeff & Amy
"Just Enough"
Oneonta, NY
Thanks, Jerry
Oneonta, NY
