I went to buy a solar panel to hook into the SAE. I'm very confused. Is this a zamp connection? Is polarity reversed. Almost bought a Dokio but someone said I would have issues because of Zamp?? The more I research the more confused I am. Anyone know about solar hookup on the 2022 cs-s?
0 ·
Basically, you just need to make sure the positive (+) and negative (-) cables from your solar panel/solar suitcase are properly aligned/connected to your solar (Zamp) port at the trailer. Often, that requires an adapter between the two so that the connections match (i.e., same polarity, or "+" to "+" and "-" to "-".)
https://tab-rv.vanillacommunity.com/discussion/6230/zamp-solar-connections-explained
https://tab-rv.vanillacommunity.com/discussion/2973/please-help-renogy-solar-panel-wiring/p1
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
2017 F-150
Coeur d'Alene, Idaho
