It happened one afternoon on I94 eastbound just west of Miles City in eastern Montana. It was over 90 degrees, sunny, and a bit humid. My sister and I had a lot of trouble getting the clamshell to latch in the hot Montana sun before departure. It felt like the clamshell itself had swelled because the latches were not catching the receiving pieces on the body.
While cruising east on I94, I noticed the black rubber strip (the one covering the bolts) had come loose and become a streamer. Immediately after noticing that, I saw thin, white objects flying backwards from the clamshell. The latches had given way and the clamshell was open! Those white objects were sheets of paper towels having a party unrolling. I didn't have duct tape with me (I do, now), so we did our best to close it again and proceed 7 miles to Miles City. Borrowed some tape from a nice semi trucker that asked how I liked the T@B because he and his wife were looking for something small.
Tape held the rest of the 700+ miles to home. Have any other clamshell owners had this issue in the heat or any other conditions? I don't trust those latches. Seems like a design adjustment is in order and/or a second method of closure. I purchased the T@B early July 2014, so I am hoping the dealer and manufacturer will resolve under warranty.
Beth
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V82018 Jeep Wrangler Unlimited Rubicon 6 speed manual
0 ·
This is a common occurance, and this is how Ed or Marvin fixes the galley doors at the factory. The level of humidity does affect how the doors fit. It's just a fact. It took a year for my right side to need washers and another 6 months for my left side to need them.
And, in reading the forums of other manufacturers, it's not just Little Guy.
Minnesota
Minnesota
The only other latch that I'm aware that was considered was one with a hook, instead of the straight piece latching behind the "handle-looking-mechanism". I don't know if the person actually changed them out.
I do understand your concern, and it happened to me, but I realized it when I tugged on the galley door before leaving camp.
Yes, you get a little OCD about being sure to tug on the latch handle at every stop and a half a dozen times before you leave.
I was satisfied with the washers. It worked, and I made sure it was a tight fit since I figured out that humidity, or lack thereof, was the culprit.
Minnesota
Bungee cords, great idea for added support and piece of mind.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Minnesota
Sometimes that just doesn't work on the LG products. I tried that last winter in Arizona, and it just wouldn't reach the "handle" on the floor. It took the washers to get the "handle" up high enough for the lever to reach.
John & Lori in Northern VA
Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B"
2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
Minnesota
MOUSE-KE-T@B
Harvest, AL
Minnesota
Clamshell latch receiver on galley floor (3rd photo) fits S-2 square recess (I also have one marked R-2 that works)
Clamshell latch adjustment on clam (1st photo) fits 1/8" hex/Allen (one of my T20 heads also worked, but the other didn't)
Second photo shows what I think to be the correct application of 2 washers to raise the bracket
Minnesota
Steve
West Chester, Ohio; 2015 Sofitel CS; 2015 Ford Escape
Steve
MOUSE-KE-T@B
Harvest, AL
Hudson NY
http://visitedstatesmap.com/image/AZARCAIDMEMTNMNYNCOHORTNVA46a202e63ca94611359453788a0e1524408907xlg.jpg
