Fresh water cap
Danner
Member Posts: 11
The cap to the fresh water input has snapped off...it leaves the fresh water input exposed...for now I have a rubber stopper in the input hole. I'm trying to find a replacement part for it but don't know where to look. I have a 2017 nucamp Boondock edition. Any suggestions?
Do you mean the freshwater tank or the city water connection?
My freshwater tank flat lid snapped of recently when I was leaning a fill up jug on it too much.
It snaps back into place with some effort. It has one small bump on each side that fits into one small hole on each side of the fill.
If you get it in place on the one side, you can push the other side into place. I ended up using a piece of wood and a hammer to tap into place.
Let me know if you need more info, but I wasn't even sure if that was what you meant...2020 T@B 320s Boondock Lite. 2015 Kia Sorrento EX V6 AWD -
I second @Sharon_is_SAM choice of freshwater fill, it will support a fill-up jug well. Installing it and getting the hose clamp on and tight can be a challenge if working through the hatch above the toilette without losing tools.Kay and Tom - SW Wisconsin - Silver T@bernacle - 2018 T@B 320S Boondock Silver/Black trim TV, 2018 Chevy Colorado, Silver/Black trim, Duramax, TowHaul, IntelliHaul
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
