Stabilizer maintenance
CanadianTabber
Member Posts: 148
Hi all!
After a longish trip, the stabilizers are caked in grime, road dirt etc..what is the best lubricant to use after they have been cleaned up?
Thanks!
Brent
Thanks!
Brent
Toronto, Canada
Toronto, Canada
I use T-9 by boeshield. I really think its one of the best lubricants you can use. You can get a 12 oz spray can from Amazon.
BOESHIELD T-9 Rust & Corrosion Protection/Inhibitor and Waterproof Lubrication
2021 T@b 400 BD "Vixen Gail"
Leadville Colorado1 -
I agree with T-9. Hose off the stabilizers with the water hose, let them dry, and then spray the T-9 on the threaded rod. A little T-9 goes a long way and it is expensive so there is no need to drench the rod till it drips off. Start spraying at the top and let the T-9 run into the nut. Then run the stabilizers up and back down. that will spread the T-9 along the entire run of the rod. You can also spray the swivel points at the pad itself at the bottom of the stabilizer. The really nice thing about T-9 is that it is wax based and provides lubrication after it dries. And, it will not attract dust and dirt as does WD-40.1
CRC 03084 11oz Dry Moly Lubricant Aerosol Spray
This product was recommended for this application on a YouTube video I watched before:
https://www.amazon.ca/gp/product/B0013J62P4/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure1 -
Thanks for the excellent suggestions!2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada1 -
https://www.youtube.com/watch?v=fLnnClHnMyM
