Greetings,
We are thoroughly enjoying our 2014 T@B CS, purchased new in December, 2014.  However, we've had a couple of issues on our two most recent outings, both of which were while dry-camping.
A month ago, the entire electrical system when dead on the second night.  When I hooked it back up to the car for the return trip, the trailer lights and electric brakes did not work.  After towing it home without lights/brakes, I plugged it into shore power and, once charged, everything worked fine.  So, I assumed something had been left on at the camp, but didn't understand why nothing worked when hooked up to the car's electrical.  It remained on shore power until this past weekend's trip....
This time, on the second night, the heat/water heater system (Alde) and the refrigerator stopped working.  The inside lights and propane stove still worked, only the heat & refrigerator were non-functioning.  I hooded it up to the car and towed it home (trailer lights and brakes working fine).  When we arrived home, the refrigerator was working.  I turned on the heating system and it was working, also.
This is my first RV and I have no experience with these types of systems (Alde, inverters, etc).  Charging issue? Battery issue?  Propane issue?
A few more notes on our T@b;  Always plugged into shore power when stored; battery acid level always at full; propane tank has a gauge attached; T@b was separated from tow vehicle at campsite.
Any help with which way to go on troubleshooting these issues would be appreciated.  The nearest dealer is 3hrs away, so I would fix it myself, rather than seeking warranty work, if the cost is reasonable.
Thanks Gang!
                0 ·
Sterling, VA
Be careful with monitoring your battery charge. The 12v batteries shouldn't be discharged more than 50% to maximize their useful life. Also, low voltage can destroy electronics. I fried a television that way. Pick up an inexpensive 12v battery monitor that you can plug into a 12v outlet.
Hope this all clears up for you! Electrical snafus are so frustrating. My wireless brake controller wasn't working yesterday--turned out to be due to a blown in-line fuse near my vehicle's battery. Then my fan wasn't working, and that turned out to be due to the remote control coming somehow "unpaired" with the fan. So, anyway...I can empathize!
I think switching the ground is a questionable way to do it, unless you're only switching off the battery's ground wire, and all the other ground wires are still connected.
The ground needs to be there for two different and separate electrical systems.
The Tab's 'house' electricity, supplied by the Tab's battery, runs the 12v electrical appliances and interior lights.
The TV's electricity, supplied to the Tab by the 7-pin connector, runs the driving lights and electric brakes, while also supplying a charging current for the Tab's battery.
As others mentioned, a bad ground connection could cause problems with both systems at once.
