Maxcamp
Member Posts: 347
Dream Lighting 12Volt LED Panel Light with Switch - 5" White Shell Ceiling Downlight - Warm White Panel Downlight for Kitchen, Roof, Cabinet and Cabin
https://www.amazon.com/Dream-Lighting-12Volt-Panel-Switch/dp/B00ODVEWPG/?th=1
select: Color: 5inch, Dimmer Switch, Warm White Light
There is little slack in the Nucamp wires. Pull the fuse, cut the crimp splices near the middle and pare back to conserve wire length.
Crimp on INSULATED spade terminals to trailer side and to new light. Coil up slack inside the cutout in the 1/8" hardboard liner.
Very gently hand tighten the #2 square drive screws into the hardboard.
Nucamp did not vapor seal the bath light, permitting shower vapor to penetrate the headliner.
mfgr. info:
Manufacturer Jerrylight Pty Ltd
Brand Dream lighting
Item Weight 3.88 ounces
Product Dimensions 5 x 0.8 x 5 inches
Country of Origin China
Is Discontinued By Manufacturer No
Manufacturer Part Number 0016937W-milky lens
Bulb Type LED
Special Features Low power consumption to save energy, Shock and vibration resistant, Dimmable, 12volt DC for vehicles
Mirror Lighting Type LED
Amperage 0.3 Amps
Voltage 12 Volts
Wattage 4.7 watts
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
They also do not have the tiny led blue idiot lights that demarc the switch, so likely do not have the parasitic draw you measured on original light model.
Should arrive tomorrow.
Good news for me as it will free up a switch on the panel I installed to cut power to everything that was a parasitic draw on the battery. I will use that switch I was using for the overheads to turn the blue tooth transmitter for a wireless speaker on and off I'm installing on the Jensen.
Use a plastic autobody prybar or wrap a butter knife with tape and gently pry around the outer edge in a few spots, starting in a less visible location on the headliner. You need a square drive bit for the base screws in the fixture beneath.
They just pop off. If you got the same replacements I did the rings are interchangeable so if you crack one it's no biggie. Stick your fingernails under one side edge and put your thumb on the lens and pull.
The button works very reliably, unlike our old one, and the dimmer function is a welcome relief too.
I cut off the old unit, leaving a couple inches of wire to use, then added some heat shrink tubing over the old connections..
Then I added 2 pairs of spade connectors to connect the new wires (shown above before heat shrink tubing was slid up over them). As previously mentioned, the screw holes all lined up with the originals.
Thanks again.
