Damages keder rail - what is underneath?
immanence
Member Posts: 102
See attached photo. Hit a clothesline and it bent my keder rail and mashed in the rubber sleeve a bit. I think I can bend out the keder rail pretty easily, though this is on the non-door side so maybe it doesn't really matter. But what is underneath the rubber sleeves? Any other damage I should be concerned about? See attached.
https://ibb.co/870NYk5
Not sure if the “rubber sleeves” is the black, plastic trim, but if so, it is decorative. It covers the area where the sidewall meets the roof. I suspect the damage is cosmetic.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Yeah, that is it. Thanks!
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
