2018 T@B400 Dometic AC maintenance
I recently purchased  a 2018 - T@B400, and want to clean and possibly replace the Dometic AC filter. Since I don’t have a maintenance manual, I am wondering how to access the filter ? Is the access point under the front seat ?
  • qhumberdqhumberd Administrator, Moderator Posts: 703
    Patrick of Travels with Delaney covers this in his video. should be a couple of #2 Robertson head screws. On plywood seat on passenger side
    https://youtu.be/Jt1zOte9oZc
    Yes, you remove the driver’s side dinette seat, and in the front lift out the filter.  You can rinse it in water, allow,it to,dray and replace.  It has a slide channel that holds the filter in place.  Newer TaB 400s have a hinged door to access the filter.  I am considering making an access doe on my 2018 TaB400.
