Before I start:
I've not been having a great computer or computer keyboard afternoon. I wrote a longg and detailed post on this topic but then it just disappeared . . . and no I did not use the 'save draft' feature . . . my error. Then I was writing a PM to another forum member and must have hit 'control/shift' instead of 'shift' and the entire message disappeared . . . . So this will be a short post!
I have been using a battery powered thermometer in the Fridge to monitor the temperature. Over the years I've thought - - - I need something that won't require opening the door just to check the temperature - - - and this week I finally did something about it {{save draft}}.
Cutting the hole to mount the display was the most difficult step . . . and the picture shows I'm not a cabinet craftsmen . . . maybe a little caulking material will improve the look(?) . . .
The Display I installed only reads in Celsius so I added the label with a couple of key temperature conversions; after-all I'm in the U.S.A. one of three nations that use imperial and the only 'industrial' nation of the group. {{save draft}}
This display was selected because it includes a Relay Control Output so a future project for having minor temperature control while operating on 12VDC might be added. I also installed a toggle on/off switch (near Norcold marking) so the display can be turned off for sleeping.
28.6 C ~= 83.5 F - - Fridge was off and outside temperature was 90+F
'18
320 S,
pitched axle, 3020HE; PNW based
2020 T@B 320 S Boondock Edge, 2020 Subaru Outback
