Isn't this producing 24v?
slick2699slick2699 Member Posts: 3
Hello! Recently bought a 2022 320 boondock which to my surprise had 2 LifePo4 100ah batteries installed. Everything runs as it should but after taking a closer look it appears they are wired in a series, which as I understand should be producing 24v?  I'm a newbie so I assume it's fine, but what am I missing?  Thanks!
  • rh5555rh5555 Member Posts: 536
    Your photo shows batteries connected in parallel - positive to positive and negative to negative.  As it should be. Series connection would involve a positive to negative connection between the batteries.
  • MuttonChopsMuttonChops Member Posts: 1,909
    @slick2699 ;  Your Batteries are correctly connected in Parallel.
    In fact the Go Power literature states they can not be connected in series. (perhaps because that will confuse the built-in BMS {battery management system})
    You can tell the batteries are in Parallel because the Positive Terminals are connected (shorted) together.
    The figure below is from the Go Power 'Quick Start' flyer.
  • slick2699slick2699 Member Posts: 3
    Thanks guys, i see now.  I think the flipped 2nd battery was messing with my head.
    edited July 2022
    yes, that is odd.  I would flip the one battery back the other way round (as shown above in the illustration) and use shorter AWS no 6 battery cables to reconnect them back in parallel.
