Two openings on T@b400 drivers side
any idea what the two new openings are for on the new 22 400’s?
2021 T@B 400 BD / 2020 Ram 1500, Northwest Arkansas
  • VictoriaP
    VictoriaP Member Posts: 1,496
    Looks like fridge vents?
  • USSBird
    USSBird Member Posts: 68
    DW thinks it’s part of a all new anti snoring baffles.  I am going with extra vents for optional keg/wine fridge 🤣
  • RayJim
    RayJim Member Posts: 145
    3-way fridge vents
    2021 T@B Boondock 400. 2021 Toyota SR5 V6
  • Denny16
    Denny16 Member Posts: 5,431
    That is a 2022 TaB400, built before May 2022.  The vents are the 3-way option fridge which needs external vents for the propane burner system.  This is not longer an option, as this Isotherm 3-way fridge is no longer available and has been replaced by a larger 2-way fridge, which does not require external vents.
  • dragonsdofly
    For sure they are fridge vents, lower to intake cooler air and upper to exhaust hot air. Identical to the vents we have on our 2006 Keystone Laredo for our 8 cu ft fridge. Our fridge is propane and 110/120 V only, but the vents are necessary for cooling the cabinet surrounding the fridge when it is operating on propane.
