Two openings on T@b400 drivers side
USSBird
Member Posts: 68
any idea what the two new openings are for on the new 22 400’s?
2021 T@B 400 BD / 2020 Ram 1500, Northwest Arkansas
Looks like fridge vents?2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
DW thinks it’s part of a all new anti snoring baffles. I am going with extra vents for optional keg/wine fridge 🤣2021 T@B 400 BD / 2020 Ram 1500, Northwest Arkansas
3-way fridge vents2021 T@B Boondock 400. 2021 Toyota SR5 V6
That is a 2022 TaB400, built before May 2022. The vents are the 3-way option fridge which needs external vents for the propane burner system. This is not longer an option, as this Isotherm 3-way fridge is no longer available and has been replaced by a larger 2-way fridge, which does not require external vents.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
For sure they are fridge vents, lower to intake cooler air and upper to exhaust hot air. Identical to the vents we have on our 2006 Keystone Laredo for our 8 cu ft fridge. Our fridge is propane and 110/120 V only, but the vents are necessary for cooling the cabinet surrounding the fridge when it is operating on propane.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
- 916 Introductions
- 72 Teardrop Groups & Links
