2018 Tab 400, replacing Jensen JWM70A: iRV68 or Furrion DV1230?
The Jensen never really worked. BT never connects anymore regardless of tricks applied. I also would really like HDMI input on the front panel as I never use disc format for movies - only downloaded to iPhone. I've found th iRV68 and the Furrion DV1230 and I'm leaning toward the DV1230. Anyone else chosen either of these? Any gothchas I should be aware of?
Thanks!
  • mrfirmwaremrfirmware Member Posts: 5
    I ordered, checked and returned the Furrion DV1230 since it would not fit the depth with the cables in the rear. So that's out. I think the iRV68 is out for the same reason.
    Does anyone have a good option for replacement?
    Have you considered new Jenson, nüCamp is currently using, no reports of BT issues and no DVD player in it.  It is a cube shape, so a add on cover panel to change hole size would be needed.  A black or dark gray plastic panel would work.
  • DenisPDenisP Member Posts: 543
    I have had great luck dealing with Crutchfield. Their support folks are very knowledgeable and they have a wide selection of products.
    2013 Tundra TRD 5.7L
    Massachusetts
