Question about drain fresh water, 2022 320S Boondock
CCC
Member Posts: 118
When you turn the black drain valve is the water supposed to come out of the blue tube in the middle back of the camper or does it just flow into the gray water tank?
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
North Georgia
If you are emptying the fresh water tank via the tank drain, it drains onto the ground. If you use the pump and open a faucet/shower, it drains into the gray tank.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I had the pump on trying to drain the fresh when I turned the drain fresh water tank valve, I guess that's why the tank didn't drain out the plug. Lesson learned.2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
