We have a tab 320 cs-s boondock with Factory Solar. I've added in a separate solar panel and controller (Goal Zero Boulder 100 and Goal Zero 10 controller). When you have multiple controllers do the settings for bulk, float, absorption levels need to match? I'm assuming that if they are different one of them may go into float mode will the other is still charging but will that cause any issues?
The goal zero doesn't seem very configurable while the Victron Connect seems like it might be possible to start a global conflict if you mess up the settings.
Thanks.
Alan
2022 Tab 320cs-s
2020 Honda Ridgeline
0 ·
managed by VE Smart Network
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
