2021 Tab 320S Stuck toilet cassette access door
Mikemcg
Member Posts: 4
Unlocked position both buttons push in the top unlatches the bottom doesn't. Anyone run across the problem? Tried to get a credit card in but can't get at it. At some point I'll need to get the toilet out as I'm on a month long trip.
I would probably try shooting some silicone spray in both areas. Use one of the small red tubes on the spray nozzle and work it in by pressing the buttons in and out and see if that helps to get it to release. Might be dirt or something interfering with the operation of the door. Get another hand, use a thin screwdriver to gently pry along the edge with buttons pushed in. See if that helps out. Once things improve check the door operation to ensure it doesn’t happen again.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
Thanks Mike - tried silicone and passing a wire down to unlatch and finally was able to break the bottom latch without messing up the door. Turns out the spring in the mechanism was out of alignment. So no bottom latch now but can access the toilet. The bottom latch seems somewhat redundant anyway. May see if I can get a parts replacement from Nucamp.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
