Tab 400 keder rail
Lakgood1
Member Posts: 1
Does anyone know where I can purchase 2 feet of Keder rail.
It might not work in your situation but I made a homemade awning using 3/16” plastic coated cable from Lowes. You buy it by the foot.2019 T@B 400 (for sale)
2017 Highlander Limited -
@Lakgood1
Do you mean the metal Keder rail that is attached to the trailer and into which the awning slides? If so, you will probably have to see if it is available from NuCamp through a dealer. But I'll bet it will only come in longer lengths than 2 feet.
UPDATE--
Google suggests this place: https://lightweightmanufacturing.com/keder/keder-rails-extrusions/ -
I purchased mine from sailrite.com. By the foot and 5/16” size as I recall. They have both the rail the rope.400 - 2019
St Catharines, ON -
@RMo how did you attach the cable from lowes to your tarp? Thanks!
Dona & Ben / 2019 T@B 400, no solar, 2008 Tundra / Boise -
I folded the tarp over the cable and attached it with short almost-color-matching pieces of duct tape every few feet. The tarp was held fast to the cable at both ends. Note that the tarp I used was the very thin nylon type. Mine was 10 x 10 but larger would work. Good luck!Dona said:@RMo how did you attach the cable from lowes to your tarp? Thanks!2019 T@B 400 (for sale)
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
