@Lakgood1 Do you mean the metal Keder rail that is attached to the trailer and into which the awning slides? If so, you will probably have to see if it is available from NuCamp through a dealer. But I'll bet it will only come in longer lengths than 2 feet.
@RMo how did you attach the cable from lowes to your tarp? Thanks!
I folded the tarp over the cable and attached it with short almost-color-matching pieces of duct tape every few feet. The tarp was held fast to the cable at both ends. Note that the tarp I used was the very thin nylon type. Mine was 10 x 10 but larger would work. Good luck!
2017 Highlander Limited Platinum
UPDATE--
Google suggests this place: https://lightweightmanufacturing.com/keder/keder-rails-extrusions/
St Catharines, ON
