propane refrigerator not getting cold
I have a 2017 TAB 320s . The  propane refrigerator not getting cold. Its on and gets a little cold but before it would freeze a water bottle when on high.
    MuttonChops Member Posts: 2,085
    Just some general questions:
    1 - -  This is model 3136 3-way correct;
    2 - -  Does the Fridge get good and cold on 120VAC?
                If yes, then issue is with propane heat source.
                If no, the cooling gas "ammonia" may have leaked out.
    3 - -  Has the trailer been stable and fairly level for the past 3-4- days?
                Extreme trailer left/right or tongue up/down can disrupt the ammonia distribution.
    4 - -  Have you observed the Propane Flame . . . does it change size as the flame control knob is
                 changed from high to low, low to high (remember to press knob in while changing flame setting.
    If:
        2    =   Yes, OK on 120VAC
        3    =   No, just normal storage or driving.
        4    =   Yes, seems to be getting more propane at high setting
    Then, you might try cleaning the burner assembly,  Service Manual reference:
  • banjer54
    banjer54 Member Posts: 21
    Thanks I'll try plugging it in and see. It has been  level .
  • banjer54
    works fine with 120. Must be flame not right
  • FuzzyYanni
    FuzzyYanni Member Posts: 110
    edited October 2022
    @banjer54
    Did you manage to replacle the orifice burner ? if so did you have to pull the fridge?
    from the orifice shape it looks impossible to remove due to the metal collar with the round hole for a set screw.... (see red arrow)
    "I know one thing, I know nothing."
  • banjer54
    I'm just getting back to this. had to put away for the winter. The gauge shows it lit. something is dirty I have to pull it out but not sure how to
