Historical Battery min/max captured while battery disconnect in “off” position – relevant?
No worries Marlee, glad to help you sort the out. The inverter, I believe, has a low power cutoff, so when the battery voltage dropped past a given level, the inverter will switched off, saving your battery from a complete discharge.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
