I am planning to purchase the Victron Energy Smart Battery Sense. I realize it needs to be physically connected to my battery but want to make sure that it connects to the Victron Charge Controller via Bluetooth. In other words, can someone confirm that it does NOT need to be connected physically (hardwired) to the charge controller AND the battery? Based on
these answers, that appears to be the case.
I obtained the idea for this from Will Prowse, but in
this video, he connects the Smart Battery Sense to both the controller and the battery.
If that's the case, I am going to look into some kind of warming pad when we are winter camping and connected to shore power. If any of you are utilizing something like that, I'd love to hear what you are using.
2018 Nissan Frontier 4x4
SW Ohio
2022 T@b 320 S / 2021 Subaru Outback
As far as temperature control you don't mention the battery make and model. Some batteries have temperature cutoff builtin to the LifePO4 battery BMS. The BMS will prevent charging and discharging during low and high temperatures in factory constructed LifePO4 batteries. If you want to continue charging in cold temperatures then a battery heater as mentioned above or relocate battery to cabin to keep it warm.
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r
