Changing a flat
MikeRog
Member Posts: 1
Hello All
New to the forum , so thanks for having me Just picked up a 2015 Little Guy 5 Wide . Really nice . Have had trailers in the past like Casita and Scamp . Read the manual for changing a flat . NuCamp says raise the entire camper up on the stabilizer jacks and front crank .??? In the past I have placed a bottle jack on the frame as close to the axle as possible with a piece of 3x4 by 2" piece of plywood between the top of the jack and the frame . Is there a reason NC does not want you to support the frame in this manner . I feel sure this has been discussed before so thanks for your replies
Thanks for the replies mike
That maneuver to use the Jack and stabilizer to change a tire is no longer recommended, so, please disregard. You should use the Jack plate as you have described. https://nucamprv.freshdesk.com/support/solutions/articles/44001800473-changing-a-tireSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
