Using Jensen DVD player
Having a problem with dvds that just continue loading and never start. Any help would be appreciated! :)
    MuttonChops Member Posts: 2,085
    That's not sounding positive.
    Assume you have tried different CD Disks . . . .
    My Jensen {DVD Reader Style} unit has only had "loading issues" when I inserted Blu-Ray disks instead of the slightly older format DVD disk.
    And I felt soooo dumb for having brought the Blu-Ray movies - - - -
    qhumberd Administrator, Moderator Posts: 913
    We have a 2019 T@B 400 that had a loading issue that some first aid was in this thread if you have that model
    https://tab-rv.vanillacommunity.com/discussion/9927/2019-jensen-jwm70a-dvd-cd-radio-loading-loading-loading#latest
    ASA replaced ours even though out of warranty
  • Mickerly
    Mickerly Member Posts: 514
    Assuming you have a DVD disk, try a music CD. If it loads correctly, your movie disk is bad. If the music CD doesn't load either, the lens on the laser is dirty. I cleaned mine; however, it took a lot of disassembly. I wouldn't recommend it without serious consideration.
    2018 320CS-S
    "Just Enough"
  • Linfran
    Linfran Member Posts: 2
    thank thank you - will try that
  • Marceline
    Marceline Member Posts: 1,779
    In addition to other suggestions, I'm just going to mention that it will not play BluRay disks.
