2018 t@b 320s…I forgot to check upper exterior vent cover and it blew off, taking the fan with it. Can’t use my fridge until fan is replaced. There are a couple loose wires but the thermocouple is still attached. The fan was factory installed and attached to the vent cover. Suggestions for efficient, quiet fan welcome. Simple to install would be great too.
Thanks for input, tips. links. This will be an expensive ‘oops’.
                0 ·
https://tab-rv.vanillacommunity.com/discussion/2635/noisy-norcold/p1
Pretty much any 12V fan typically used for PCs will be fine. Just make sure it's the right size and a 2 wire 12V DC fan.
Huntington LI
