2009 T@DA - Brakes and Bearings? (SOLVED)
FuzzyYanniFuzzyYanni Member Posts: 112
Hi Folks !
We have a 2009 T@DA (Dutchmen) and would like to purchase replacement Bearings and Drum Shoes (or the whole brake assembly)
Has anyone replaced these parts with off the shelf  parts?
If so could you please share the part numbers with us?
Thank you
SOLUTION:
Dexter Trailer Hub and Drum Assembly for 3,500-lb E-Z Lube Axles - 10" Diameter - 5 on 4-1/2
These brakes look EVEN better:
https://www.etrailer.com/Trailer-Brakes/Dexter/23-468-469.html
Wheel Bearings – MasterPro Trailer Bearing Kit – Part # BT7 (one kit per wheel is required)
https://www.oreillyauto.com/detail/c/masterpro-bearing-seal/agriculture-hd-parts---accessories/fleet---heavy-duty/hubs---accessories/trailer-wheel-bearings--seals---kits/872782d67c89/masterpro-trailer-bearing-kit/mpb0/bt7
Trailer Bearing Kit; Consists of:
1 - A17 Bearing Set (L68149/L68111)
1 - A4 Bearing Set (L44649/L44610)
1 - 442251 Seal
1 - Cotter pin
Brakes -
This bearing kit looks will be also work (order two kits, one per wheel)
https://www.etrailer.com/Trailer-Bearings-Races-Seals-Caps/etrailer/BK2-100.html
"I know one thing, I know nothing."
