I've always wanted to use my TAB 320 water system in the winter at our local ski area instead of lugging water jugs around.  Inspired by a brilliant mod posted by
@Gregp, I came up with the scheme illustrated in the attached diagram.  So far, I've tested it in near freezing temperatures here in town and it works well.
The plumbing was quite challenging because of limited space in the cabinets under the sink and there wasn't enough room for a conventional PEX compression tool.  I found the below item on Amazon and it worked OK with no leaks.   The water tank fill line conveniiently runs through the right bottom edge of the lower cabinet where I added a pvc "T" to connect the hot water output line from the solenoid.
Needless to say, there were multiple trips to the hardware store
Solenoid:
Thermostat relay:
I insulated the water tank and undercarriage fill/output water lines with a combination of materials.  I also applied a layer of insulated and reflective auto windshield sunshield material to the entire inside surface of the corrrugated undercarriage cover.
The true test will come this winter.  I'll post a followup in a couple of months.
Geoff
I just dropped the plastic cover underneath, ran a heavy gauge wire from my battery array to bus bars, and wired up Facon heating pads on all exposed tanks and plumbing.
2022 T@b 320 S / 2021 Subaru Outback
