T@b 2017 Boondock
Does the 2017 T@b 320 s have a 2 inch receiver couplet? Do all T@bs have the same receiver couplet?
    2 inch receiver is standard for all TaBs.
  • MuttonChopsMuttonChops Member Posts: 1,908
    Welcome to the Forum.
    To reduce possible future confusion knowing the standard terms for the towing components might be helpful.
    TaB Trailers have a 2-inch Coupler,  that requires a 2-inch tow ball.
    The Tab 320 is light enough that the tow vehicle could have a 1.25-inch or a 2-inch receiver;
    the hitch mounting point installed on the tow vehicle by manufacturer or aftermarket.
    Most standard size SUV's have a 2-inch receiver that is rated at Class-III {how much weight it can handle}
    Some smaller SUV's may have a 1.25-inch receiver that is rated at Class-II.
    For towing a TaB 320 the tow vehicle must have at least a Class-II receiver, a compatible tube size tow bar, and a 2-inch tow ball on the tow bar.
  • SMoore0865SMoore0865 Member Posts: 5
    Thank you that’s very helpful .
