I think this category might be more appropriate for my posting......
One of my windows is coming loose at the top and it seems that the screws are stripped. My thought is to try larger screws. Any other advice or considerations welcome! These screws are good to add to maintenance check as they are not usually visible.
Around the window cut-out the sidewall has a thin metal foil to help screws "get a grip" since the rest of the wall is just foam board.
That said, if several screws are 'stripped' you might consider using a bolt with a fender washer on the inside (cabin side) of the wall.
For reference:
Adventures: 51 Nights: 322 Towing Miles 41,200+
2020 Tacoma TRD Off-Road
2022 T@b 320 S / 2021 Subaru Outback
= - = History, Ramblings . . . . Square Drive Screw = - =
At some point I heard/read an urban legend that Dodge created the Phillips Head screw due to royalty disputes with Roberson. Which according to several different history articles is not what really happened.
In short:
= = Roberson invented the Square Drive in 1907/08.
= = Henry Ford used it 100% on the Model-T assembly line.
= = Ford wanted to modify and control the screw production, Roberson said no.
= = Ford and others continued to use the Square Drive but were not happy.
= = In the 1930's an Engineer (Thompson) and a Businessman (Phillips) created the Phillip Head drive.
= = in 1936 General Motors used the Phillips screw in the 1936 Cadillac.
= = The Phillips Head became the standard because Phillips allowed users to modify the design.
+ + While the Roberson is a better screw drive when compared with slotted and Phillips-head
screwdrivers as the Robertson worked faster and with less cam-out. However, cam-out was good
for automakers increasingly relying on automation, as it meant screws wouldn’t be overtightened.
A history article:
https://www.roadandtrack.com/car-culture/car-accessories/a33490602/phillips-head-screwdriver-history/
out-of-the-slot is a pain.
