Hello, I’ve searched the forum threads and understand additional AC outlets can be installed. For my 2018 320s/cs I would like to install an outlet by my interior front cabinet top to plug in a small ceramic heater to jump start the Alde. The only ‘accessible’ outlet that I’ve found is under the rear cabinets which is a no-go for the heater since I leave the bed set-up. So my questions are, can it be done for the location I’ve chosen? And with all the talk about converters etc, do I need to go to an RV service center or NuCamp dealer? It sounds like it’s more than a DYI project for just me, but perhaps with some instructions and the help of an electrician friend?
I am a newbie, and don’t want to throw a lot of money into a project that I’m only going to need a few times a year. So any alternative work-arounds would also be appreciated.
Thank you everyone for contributing to such a great resource! 🤗
Liz S. aka Bizzy B
2018 T@B CS/S
2014 GMC Acadia w/tow pkg.
Northern CA
My 2018 320S {wet-bath, kitchen, no outside kitchen} has a 120VAC outlet above the Sink.}
It is not clear as to what your set-up is now, and where you'd like an additional 120VAC outlet.
Northern CA
Northern CA
Northern CA
that is use the available outlets and a quality extension cord.
That said, I am surprised the 2018-yr units don't have a 120VAC outlet for the front countertop.
In any case, I've located the images below to illustrate the route one might take and the possible structural features in the area..
I assume this is what your wet bath looks like, @ObizzyB ?..
The dotted line represents the route for a power line from under the driver side bench seat, under the shower, behind the toilet wall, and to the wall at the cabinet.
And another floorplan view..
And the green box below would be the target area for mounting an outlet..
Below is a shot of the area under our driver side bench seat near the front of the wheel well. Circled in green are the AC cables running from the converter area to the raceway that goes under the shower floor pan and into the space behind the toilet wall..
You may be able to wire a new 120V cable from the existing GFCI outlet in this area to extend power (& protection) to the new outlet.
Next below is the view inside the wall where the outlet would be mounted & the route for the cable.
As mentioned, there is a double wall in this area left of the cabinet, with only about an inch of space inbetween. If one layer is already cut out, as shown, then you may be able to use that space for an outlet box, but this may require relocating an existing display, if possible.
Otherwise, a shallow surface mounted outlet box is another option, which would probably be easier & may only require drilling a single 3/4" hole.
For me, this would be a fairly easy project, but it would require having the right power tools, like a drill, at minimum, and possibly a reciprocating/scroll saw or a plunge cutter tool if you recess the outlet box into the wall.
The simplest approach would only require drilling one hole, then installing a surface mounted outlet box.
Northern CA
Northern CA
Northern CA
Northern CA
Northern CA
"Just Enough"
I'm in Chester, VA.
