My tires on my 2021 320S Boondock are wearing badly on the inside of each tire. I have the factory tires for the boondock edition I have about 20K miles on these tires. Not sure exactly because I purchased it used. I have put 15K miles on it. Is there any kind of allignment possible on these Dexter axles? I am not overloaded & they seem to be wearing the same on both sides. I expect I may get one more season out of these tires before replacing. Which is not bad if you look at time in service. My camper went in service in Aug of 2020 & the date code is May or June of 2020. Not exactly sure , can't remember & I'm not near my camper at the moment. Possibly even a warranty issue? If this falls under structure. 3 year warranty & transferred to second owner, the 1 year warranty on everything else is not transferred.
2021 T@b 320S Boondock
TV - 2008 Toyota FJ Cruiser
Retired aircraft mechanic from AA
2-3 several week trips per year & other trips we can squeeze inbetween our long trips.
Avid road bicycle rider. always carry a bike or 2 with us.
0 ·
Most RV shops are not able to sort that. You might have better luck with a trailer shop.
At 20K miles, you are due for tires regardless but before you head down that path, the axle needs to be sorted out.
There is one thing that you can do on your own. Inside tire wear can result from improperly pre-loaded wheel bearings. Many mechanics think that they have the golden touch to properly torque the castellated nut. Good mechanics use a torque wrench to make sure that the bearings are properly loaded.
Since there are quite a few miles on your rig, and since you lack service history, it is possible that your bearings are not properly tightened, and it is also possible that the bearings have been damaged and worn due to neglect.
When buying a used rig regardless of the miles, the new owner should pull both wheels to check the integrity of the bearings and to also check the condition of the brakes.
If the bearings are good, then alignment is the problem. You should contact Dexter if that is the case. They have been known to replace axles to address that issue.
2020 Tacoma TRD Off-Road
I checked the date code on my tires, they were manufactured 2019, Which is the 20th week of 2019. I have a trip from NC to TX & back scheduled for March. Next trip after that will be in July. My tires will be 4+ years old with 25-30K miles on them I do believe I will be changing them before my July trip.
Thanks for all your suggestions & comments
Oh well if I can 25K & 4-5 years out the tires. I just hope what ever I replace these tires with, I still get this much use out of. I would like to go with the Goodyear Endurance. I wish Goodyear made it in a more rugged tread. I have them on my car hauler & have towed it across county a few times with no abnormal wear & it has Dexter Axles also.
