Lithium Battery Low Temp Protection Question
I’m planning to replace my 80ah lead acid battery with a 100ah Lithium in our 2022 320 CSS Boondock.  Among the many lithium choices are batteries with no low temperature shut off feature. My question is: can I simply use my Victron Connect app (version 5.80) to disconnect the T@B’s rooftop solar and keep it from charging the battery in below freezing temperatures? Thanks.
2022 T@B 320 CSS
    Yes, on the the App's "Settings" page there is a "Charger" toggle switch that turns the charging on and off in the controller.
    Victron also has something called "Smart Battery Sense" that apparently can provide low temp protection. I don't really know how it works, but the Amazon reviews are pretty positive about using it for exactly what you need if that is the way you want to go.
  • WayneW
    WayneW Member Posts: 263
    I have the Victron Smart Battery Sense that is networked with the factory Victron solar controller to disable charging at low temps on an AmpereTime (now LiTime) 100aH lithium battery. I have it set to disable charging at 1 deg C. You can mount the sensor anywhere. I have mine right on top of the battery inside the battery box in the front tub.
    It has been working great this winter. I think it’s a good way to go if you do buy a battery w/o low temp charging protection.
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
  • Grumpy_G
    Grumpy_G Member Posts: 789
    Keep in mind that anything implemented on the solar side will not protect the battery when the trailer is connected to the tow vehicle, or shore power.
  • Greenhil
    Greenhil Member Posts: 30
    Good point - thanks!
    2022 T@B 320 CSS
  • Denny16
    Denny16 Member Posts: 5,430
    One could always turn the battery switch off when connected to shore power to keep it from charging.
