2022 T@B 400 Under Bed Storage
We've noticed the 2023 T@B 400 has storage access from the front-center of the bed. There's room on earlier models (my wife put the dinette cushions there in our 2022 for a while... just challenging to access with the bedding on top). Has anyone opened that space with an access door, and has pictures to share? Thanks!
    edited January 2023
    @Flinnro3 Unfortunately, the design of the under- bed storage area in the 2021-2022 TaB400s doesn’t allow for the pull out drawer without some additional modifications.  The issue is, the power wires (120VAC and 12VDC) cables, along with the water lines run through a enclosed space just inside the storage area front.  You would need to re-route any wires down against the floor to allow for a drawer to pass over them, or a false floor to cover them in a door install.
    Here is a photo of the under bed storage area in a 2021-2022 TaB400:
    The red arrow points to the enclosed chase area covering the wiring and plumbing runs going from one side to the other.  You can see some of the wires being routed inside this area on the right side view of the Alde compartment (yellow arrow).
