Any tips on de-winterizing a 2021 T@B 320CSS (Nautilus water system) would be appreciated, I don't want to haul it to the dealer and spend the $$, when I think it can be a DIY projects. Thanks.
You also could use the Nautilus Winterize settings to siphon in clean potable water and clear the antifreeze out of the water lines and the water pump.
Have you seen this? There is one for the Nautilus system,
Dewinterizing and Sanitizing (vanillacommunity.com)
Southern Maryland
