2023 Tab 400 Door Stop Fail
clarkab3
Member Posts: 4
First time out with the 2023 400 and the little door stop on the bottom outside of the door pulled right out. It’s held with two wood screws screwed into the thin Ardel and foam. Were they thinking this would actually hold? Minor thing, but now needs a new solution.
That stinks! Our 400 is 3 years old now and has the same door catch which is still going strong. I wonder if it was just not installed correctly or they've changed the way they are installed. I always assumed there was a backing plate behind that for the screws to bite into. Definitely contact NuCamp and send them that picture.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado2 -
Most likely the screws were over torqued and stripped when installed at the factory. The Azul isn't that great to use wood screws in. I'd replace it with bolts and lock nuts. That will require the inside panel to be pulled off. The doors on these are my least favorite part. The alternate is to fill the holes with epoxy and re drill to use the wood screws again. That way you won't have to pull the door apart.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York1 -
Also maybe lubricate the stop with a little grease so it doesn't pull so hard on the screws.Rich2019 T@b 400
The grease may defeat the purpose. I may just rig a bungee cord solution. Thanks all0
- 968 Air Conditioning & Refrigeration
