jkjenn
Member Posts: 6,417
As we are new to RV, this year we plan just camping in TX. Our next trip plan is 9/22 to Lake Buchana in the Hill country. Hope you and/or some LGers can be there also.
Be advised that cell service is very spotty. I had to get in car and go to higher ground to get a signal....
so while I was out I drove on up the road to replenish the ice in cooler
Pittsburgh, PA
2015 T@B CS-S Maxx being towed by Nissan Pathfinder
AEP is nice, except for that bugs. Drove to McConellsville in hopes of finding a thermocell.
Battery setup is beautiful. Very happy. I left my SAE cable that worked with reversed polarity at home so I swapped the quick disconnect cables and wah-la.
Zero cell sign at my campsite but Weboost is helping as I scout out the area.
I've hauled out the generator to run the a/c just because of the humidity.
The humidity dropped yesterday, and I'm sitting in the driveway in my T@B with the windows open, drinking a Coke, listening to the birds, wishing I was camping.
OK, break is over. No one else is going to install the battery cutoff switch, the surge suppressor and the 50 watt solar panel for trickle charging. Get up and get going, Verna!
I probably under-utilized the fan and battery. I had plenty of battery at the end of the weekend. I really only used the fridge, on propane, and the pump sparingly, and would occasionally run the fan in the evening. The battery recharged completely on solar yesterday. I am a little confused by the cigarette voltmeter. If I ran the fan, the battery reads would drop Dow to around 12.48 and then jump back up when I tired it off. Other than keep getting up to turn off the fan and check the reading, how can you tell what your real current status is? Not sure if that made sense or not.
It happened on the SS and it happens on the T@B. Michigan Mike can give the technical reason for that when he gets back. I just go by what the voltage is when the "stuff" that is going to run all the time is on. I used a battery operated fan a lot in AZ because I knew the Fantastic Fan used too much energy for my solar panel to recharge the battery before sundown. I used the FF sparingly, if at all.
Rocky looks happy! And it looks like you got s good campsite. Have fun.
Gil
It turned out to be a glorious weekend at Beaver Creek State Park near East Liverpool, Ohio. Park Ranger said it has been pretty empty all summer up to this past week's long stretch of sunshine. Friday night people started arriving by droves!
I definitely recommend sites # 21, 22, and 23. Level, shady & wooded and very deep sites, dropping off to the valley below. Only noise was from coyotes howling back and forth to each other. Only 45 minutes from Pittsburgh.
Pittsburgh, PA
Pros:
Tons of sites spread out over numerous campgrounds.
Free!!
Quiet. I was told campground "C" was the rowdiest campground and that it is often much busier at most of the campgrounds.
You could stay for up to 3 months.
Year-round camping at some campgrounds.
Friendly campers
Big sites
Not many rules, pet friendly
Water available
Bathrooms available but I did not use.
Fairly remote for Ohio
Gravel roads were in great shape
Trash cans, picnic tables, fire rings at sites
Cons:
Bugs
Some might consider dry camping a con
No stores or services close by
No cell service at Sawmill. Decent 3g close by at the overlook.
Here is a hyperlapse video of the campground:
Didn't know about AEP.
Thanks!
