Bathroom Caulk
I have a 2021, 320S.  I am having trouble with the caulk joint where the horizontal toilet platform meets the wall.  The first time I repaired it, I used a silicon caulk...which did not adhere to the plastic components very well.  Next, I used a more conventional DAP kitchen and bath seal (non-silicon).  That adhered well but was not flexible enough and the bead split after just a year.
Does anyone have any suggestions?  I was considering a 3M Marine Adhesive Caulk...but thought I would check here first.  Thank you in advance!
  • Maple_Geek
    Maple_Geek Member Posts: 216
    I'm interested in this thread. My 2022 TAB320 BD has a similar issue. The caulking joint between the wall and the toilet "separated" on our first year of use. We're not using the shower so less of a concern but I still want to fix it at some point.
    2022 T@B 320S Boondock
    2021 Toyota RAV4 TRD Off Road
    Ottawa, Ontario, Canada
    Instagram: new.t@bventure
  • Basil48192
    Basil48192 Member Posts: 437
    I'm assuming that the toilet platform is polystyrene...and silicon will not adhere to it.  After doing a lot of searching on-line, I'm going to try the Loctite 2 in 1 adhesive caulk.  One posting stated that this is one of the only products that remains flexible and will adhere to polystyrene.
  • Dame_plume
    Dame_plume Member Posts: 75
    Thank you @Basil48192  I was looking for a fix as well.
    Sylvie and Mike, Ontario, Canada / 2020 Tab 320S (Charlie) / 2021 Chevrolet Colorado LT (V6) Enhanced Towing Package
    "The only place where you start at the top is when you dig a hole"
  • Basil48192
    I will put it in within the next few days and I'll let you know how it goes!
  • Dame_plume
    @Basil48192 Looks like you got the right one!  I found that discussion about all kind of caulking:  https://tab-rv.vanillacommunity.com/discussion/16031/caulking-and-sealants-what-nucamp-uses
  • Basil48192
    @Dame_plume, thank-you!  I did a number of searches before posting and never found that!
