Bathroom Caulk
Basil48192
Member Posts: 437
I have a 2021, 320S. I am having trouble with the caulk joint where the horizontal toilet platform meets the wall. The first time I repaired it, I used a silicon caulk...which did not adhere to the plastic components very well. Next, I used a more conventional DAP kitchen and bath seal (non-silicon). That adhered well but was not flexible enough and the bead split after just a year.
Does anyone have any suggestions? I was considering a 3M Marine Adhesive Caulk...but thought I would check here first. Thank you in advance!
I'm interested in this thread. My 2022 TAB320 BD has a similar issue. The caulking joint between the wall and the toilet "separated" on our first year of use. We're not using the shower so less of a concern but I still want to fix it at some point.2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure0 -
I'm assuming that the toilet platform is polystyrene...and silicon will not adhere to it. After doing a lot of searching on-line, I'm going to try the Loctite 2 in 1 adhesive caulk. One posting stated that this is one of the only products that remains flexible and will adhere to polystyrene.
Sylvie and Mike, Ontario, Canada / 2020 Tab 320S (Charlie) / 2021 Chevrolet Colorado LT (V6) Enhanced Towing Package
"The only place where you start at the top is when you dig a hole"0 -
I will put it in within the next few days and I'll let you know how it goes!
@Basil48192 Looks like you got the right one! I found that discussion about all kind of caulking: https://tab-rv.vanillacommunity.com/discussion/16031/caulking-and-sealants-what-nucamp-usesSylvie and Mike, Ontario, Canada / 2020 Tab 320S (Charlie) / 2021 Chevrolet Colorado LT (V6) Enhanced Towing Package
@Dame_plume, thank-you! I did a number of searches before posting and never found that!0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
