All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
Does trailer have to be level when de-winterizing?
Getting ready to do this task.  My 2021 tab 320  needs to be pulled over to the water spicket and won't be level.  How much will this affect the de-winterizing process?
    edited April 2023
    At worst, the fresh water tank will not completely empty when you are done sanitizing.  As long as you have rinsed out the bleach water, you can then open the fresh water tank drain valve  and move it back to your storage spot, raise the tongue and it will help empty the tank.
  • SLJ
    SLJ Member Posts: 644
    The first time I drained water from my 2021 320S I got another gallon out of it when I tilted it back. To completely drain the gray tank I have to tilt it toward the drivers side.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
