Swap microwave for cabinet door?
subkron
Member Posts: 205
I'm picking up my 2022 T@B 400 BD tomorrow and since we needed it quickly we got it "off the lot" rather than ordering. We really don't use a microwave much and I have seen pics of other 2022s with it removed and a cabinet door in its place. I guess I'm thinking whether I can get the dealer to order a door and then return a microwave as an even swap? Is a cabinet door for the microwave cubby even an orderable item? Just though I would check here before I approach the dealer with this. I don't mind installing the door (hinges and latch) so it is really simple for the dealer. Comments?
2022 T@B 400 Boondock
South Jersey
South Jersey
The stock door that comes in the non-microwave model should fit, and should be available from nüCamp, via the dealer.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0 -
Someone on one of the FB group pages recently posted about this and I believe it cost them $120 for the door going through their dealer. Not sure what they did with the microwave.Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium0 -
I want to do this. What do I need to order, the cabinet door, and the hinge, and.... what about the trim above the door? It would need trim there correct? Sure wish we didn't have to go through a dealer. Rathe deal with Nucamp for parts.Karen and Chris
2021 T@B 400, 2018 Land Cruiser
Dallas, Texas
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view.” Edward Abbey2 -
@CruiserCamperChris I just ordered this last week thru Missouri Teardrops (Dana and Barb). It was called a microwave delete kit, $147.99. Not cheap but it is more useful than a microwave for us. Make sure they know what the interior wood is (mine is birch).2022 T@B 400 Boondock
South Jersey2 -
We just use the microwave as a cabinet...Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA3 -
I just received my microwave delete kit and looking forward to installing. Did anyone receive any installation instructions with their kit? I’m anxious about jumping into this in the blind. Thanks for any info.
Leon0 -
My “Microwave delete” kit for our ‘23 400 did not come with any instructions and was missing a few screws. Was a bit of a challenge trying to get everything to line up correctly but the end results came out pretty good.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia1 -
no instructions, I did have all the parts included. Worked out well.2022 T@B 400 Boondock
South Jersey1 -
If someone would share a few photos of the installed cabinet door it would be appreciated. Maybe a shot from the inside to see how the battens are positioned.
thanks,
Leon0 -
South Jersey0 -
subkron said:no instructions, I did have all the parts included. Worked out well.Is installation obvious? Were spring hinges pre-installed to door? Thanks, @subkron!I was content to just use microwave itself as storage. Then I tried to angle fit the gnat vac. No go. The microwave frame is an immense space stealer. Will be glad to put it in storage.2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ1
@johnfconway Installation was not entirely obvious but working thru it wasn't too bad. Hinges were no installed but that was simple enough.
@lavaitaitis et al. I took a bunch of pics when I did the install, not sure if they are useful or not but this may give you all an idea of parts provided and how they go together.
All in all the space is well used and we really like the conversion.
South Jersey0 -
Trying to get order through Missouri Teardrops moving ahead. The folks at NuCamp sent Barb at Missouri Teardrops this: I was ready to do this order and then I realized that for this year model they have to change the cabinet door beside where the microwave goes needs to be replaced as well. do you want to check with your customer if that is ok. we don't have a door for the 2020 models.Have no idea what this means. Buy 2 doors? Buy giant 5 hinge door that spans 2 cabinets?I would be surprised the combined space between microwave and adjacent cabinet changed from 2020 to 2021 models, but it must have.Has anyone swapped out microwave in a 2020 T@B 400? Thanks!p.s. the dealer go-between thing is pretty inefficient
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ1 -
The front of the overhead door faces is different, you need to rep,ace both sides if you want matching doors. The TaB400 had several overhead cabinet door styles, the original 2018/2019 has a two tone door, with a white wave in the face of the doors and natural birch Obote and below the white part. The 2020 went with a solid color door face available in two color schemes, and 2021/2022 doors have a different look with different latching hardware, and a cutout at the bottom for a hand pull. I would replace both doors to get them matching. The size of the openings, I believe, is the same on the 2020 versions and later with the microwave option.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1
I am working with Missouri Teardrops on this. I think for obscure requests like this, NuCamp takes their time even with dealers as middleman.Oddly enough, I have in garage all the 1/2" Baltic Birch laminated plywood that was the driver's side dinette bench when Air8 was replaced with Cool Cat. Plenty big to cut for door and trim piece. Would need to build it out 1/4".Needed would be spring loaded hinges, nickel-looking handle and open/close plastic hardware pieces. Finding them searching online is a bit of a minefield. Has anyone found a site that organizes these items in a reasonably efficient way for searches?2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ0
Hmmm. I just ordered the replacement door for my 2019. They asked for a picture of my current interior (blonde birch). Now I'm curious what I'll receive. I'll share when I get it.Denny16 said:The front of the overhead door faces is different, you need to rep,ace both sides if you want matching doors. The TaB400 had several overhead cabinet door styles, the original 2018/2019 has a two tone door, with a white wave in the face of the doors and natural birch Obote and below the white part. The 2020 went with a solid color door face available in two color schemes, and 2021/2022 doors have a different look with different latching hardware, and a cutout at the bottom for a hand pull. I would replace both doors to get them matching. The size of the openings, I believe, is the same on the 2020 versions and later with the microwave option.CheersRich2019 T@b 400
Horigan said:
Hmmm. I just ordered the replacement door for my 2019. They asked for a picture of my current interior (blonde birch). Now I'm curious what I'll receive. I'll share when I get it.Denny16 said:The front of the overhead door faces is different, you need to rep,ace both sides if you want matching doors. The TaB400 had several overhead cabinet door styles, the original 2018/2019 has a two tone door, with a white wave in the face of the doors and natural birch Obote and below the white part. The 2020 went with a solid color door face available in two color schemes, and 2021/2022 doors have a different look with different latching hardware, and a cutout at the bottom for a hand pull. I would replace both doors to get them matching. The size of the openings, I believe, is the same on the 2020 versions and later with the microwave option.CheersNow I wonder if the 3/4" Baltic Birch veneer plywood used in 2020s as cabinet faces and doors is no longer available? Otherwise, the hole left by microwave is the same across model years. Besides the cabinet hardware and inside support wood, all that is needed would be finished door piece and trim piece.I hope NuCamp can send hardware and support wood pieces so the 1/2" Baltic Birch doesn't go to waste.
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ0 -
If you have a 2020 T@B 400 and are contemplating gaining storage space by replacing microwave with cabinet, hardware makes it pretty expensive. We're lucky in that we have a piece of matching 3/4" veneered plywood to use as door. Not quite enough for both doors.Hardware issue is with matching pull handles and latch. Smaller, adjacent door has nice "thumb" latch and 8" nickel pull. Can't match the pull. Wasted way too much time scouring internet for similar latch. No go. The "push button" latch is now the only game in town. I like the thumb latch better.Had to buy two matching pulls. Will leave thumb latch on small door, Found a "mini" button latch that hopefully will be hidden under the 15/16" wide pull. Will not invite anyone with cabinetry observation skills into trailer, as they would be the only one (besides me) to see the mismatch!Quick question for those who have done the swapout. I am new to double spring hinges. Not attached to wood, I can't make them budge. No instructions with them and "DGN" the manufacturer doesn't have instructions on their website. Is there a release of some sort on the hinge that I am not seeing, or will it work as intended once installed? Thanks!2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ0
I was able to receive instructions from nu-Camp on the Microwave delete kit installation.
attached. I don't think everyone here has the same kit.
best regards.0 -
The ones that come with the kit and installed on the smaller door are just spring loaded. I would confirm they move with a couple of pliers before you install them. They are pretty strong springs on the delete kit we got given how wide and heavy the replacement door is. Note on my delete kit they also include the smaller door with the matching pushbutton release.johnfconway said:Quick question for those who have done the swapout. I am new to double spring hinges. Not attached to wood, I can't make them budge. No instructions with them and "DGN" the manufacturer doesn't have instructions on their website. Is there a release of some sort on the hinge that I am not seeing, or will it work as intended once installed? Thanks!Rich2019 T@b 400
This is the shelving I put in that area...
Jericho, VT2 -
@subkron thanks soo much for the pictures! I just completed my install and they were super helpful. I was curious if you have done anything to help with the 'rocking' that is caused by the gap between the horizontal piece the brackets are installed on and the top of the original box. It seems like that the screws or wood will break after some use the way its designed.0
@tlfowles Sorry for the delayed response, just kind of missed your query. No, I didn't do anything to help w/the rocking of the bracket but it is a concern of mine as well. There is quite a bit of force transmitted the to bracket by the hinge springs to cause it to rotate a bit. I did pu a pocket hole fixture a few months back (non-RV project) so I'm thinking I may be able to run an additional screw on either end of that bracket. Or, if I rely on the existing screw to mechanically support/hold the door, I'll really only need a small screw to prevent rotation.
Now that you have "refreshed" that issue in my mind, it will get added to the spring "to do" list!2022 T@B 400 Boondock
South Jersey0
- 143 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
