Clamshell owners: If your T@B came with an outside television, do you use it?
Never - removed it
Same here. Never used it. Removed it and sold it.2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
Ottawa, Ontario0 -
I'm not sure if this is the exact mount but it's very similar.grace said:@Marceline The link is broken, do you have another? I am trying to remove the kitchen TV with no luck.https://images.camperid.com/morryde/items/pdf/tv1-048h-installation-instructions.pdf
Also, as I said in my earlier post: "On my older (2013) clamshell I had to remove it by unbolting the TV mount (with the TV still attached) from the inside of the trailer."
In other words, I had to access the backside of the panel that the TV mount is attached to from the inside of the cabinet (inside of the T@B) and unbolt the TV mount from that panel (two person job as you will need one person on each side).San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
When we bought our trailer I could have cared less about either TV. With a few years of ownership we've used both TVs: the inside TV often, the galley TV infrequently. On the occasion when the galley TV is used it's been a treat. One mod I thought about is to replace the inside and galley mounts with mounts that accommodate movement of one TV from inside to the galley. With that change only one TV would be required.2019 Tab 320 CSS, 2019 Ranger TV, OH0
